This is a clevis made for linking the tie-rods to the steering rack. This part is under dynamic loading and is getting loosened. We tried using jam nuts but it did not work well. Due to loosening the thread came out of the rack and the part fractured maybe due to bending fatigue.
10
  • $\begingroup$ More of the story here : engineering.stackexchange.com/q/18551/10902 $\endgroup$
    Commented Dec 23, 2017 at 22:32
    $\begingroup$ You should look at altering the design : position of the rack or changing the position of the steering rods as the angled load will cause that thread to fail every time . The basic issue seems to be poor design. $\endgroup$
    Commented Dec 23, 2017 at 22:34
  • $\begingroup$ @SolarMike , yeah I knew the design was bad. But we had to deal with 2 situations then . 1. The tie rod position came from the instant axis to eliminate bump steer 2. The spring damper assembly was intersecting with the rack placement. hence we thought about making this type of clevis. Can you suggest me some way out ? $\endgroup$ Commented Dec 24, 2017 at 0:17
  • $\begingroup$ Move the steering rack. $\endgroup$
    – GisMofx
    Commented Dec 24, 2017 at 0:53
  • $\begingroup$ @GisMofx I mentioned it , the dampers are at that position, which are not letting me move the steering rack rearwards. $\endgroup$ Commented Dec 24, 2017 at 1:06
to prevent the nut from unscrewing, you must use either 1) a thread-locking compound (Loctite or equivalent) on the threads during assembly, 2) split lock washers, 3) an aircraft-grade castellated nut-and-safety-wire assembly, or 4) a nut with a nylon insert to prevent unscrewing (Nylock or equivalent).
  • $\begingroup$ Lock washers and nylon style locking nuts are no longer used in industry for applications involving cyclic forces. Proper design of the system is number 1, proper torque is number 2, with lock wire or castle nuts if required. $\endgroup$
    – Tiger Guy
    Commented Jan 24, 2020 at 6:18
The problem here is moments of force. Rather than stiffening the fixings, add dampers like rubber washers with steel washers either side of the rubber dampers. This should absorb much of the instantaneous moment forces while providing vibration protection from adjacent mechanisms and fixings.
The fracture is due to strain hardening of the mild steel threaded section. Really what you want is a weaker replacement section attached to the steering rack. The break occurs where the concentration of forces exceeds the elastic modulus of the bolt resulting in what happened. Ideally you want a failure to be gradual so you have warning of imminent fatiguing failure. This would be designing the bent steel section as a thinner and more flexible bit so that it absorbs much of the shock forces at motion.
