I am learning engineering drawing and confused on this.enter image description here
    $\begingroup$ Why do you think there are 8 quadrants? $\endgroup$
    – Fred
    Dec 19 '17 at 3:23
    $\begingroup$ There are 4 quadrants, by definition. $\endgroup$ Jan 18 '18 at 12:37
Tha author is describing First Angle Projection : accept it as it is - trying to change it will only lead to confusion.
You will soon be shown Third Angle Projection - again you will need to accept how it is done as both are used in industry - a symbol on the drawing will tell you what convention has been used.
  • $\begingroup$ The reason there are only four quadrants is that its describing planes in relation to a right handed rotation, not really planes as such. Atleast that was always my impression. A plane obviously has a second side as well as left sided coordinate system having separate quadrants. $\endgroup$
    – joojaa
    Dec 19 '17 at 15:09
