I am searching for information on how finite element code (abaqus /ansys) could be used to model the contact stress behaviour between 2 bearing surfaces?
The key point is that there is an additional hard coating n both surfaces so as to reduce wear.
How would one model this additional hard layer?
Would this hard layer be represented by an additional layer of elements with a higher elastic modulus?
