I'm a chemical engineer student and I have just started to learn about mass balance without reaction.
This is my problem -
I want to find Out the mass composition and mass flowrate of stream Y (the stream into the divider).
How am I suppose to do a mass balance around process 1 (involving the divider, before process 2) ?
From the problem , I don't know any of the compositions of the recycle 1 , I only know the flow rate .
This only tells me that the flowrate into process 1 is $50000+ 1500 $ . With this alone, how do I find mass composition and mass flowrate of stream Y
In generel for N species you have N mass balances. So in your case 2. Also mass is conserced ( other than moles when it comes to chemical reaction). So you definitely know that the mass flow rate of Y is 1500. Also have in mind that the divider doesn't change the composition of your species and you also know the composition of product 1 ( have in mind that all species together sum up to 1). I think from this point on it's not so hard to find out what Y is.
Let $F$ be the mass rate of feed 1, $x$ be the mass fraction of $N_2$ in feed 1, $y$ the mass fraction of $N_2$ in stream $Y$ and $R$ the recycle rate.
From conservation of mass over process 1:
$$ F + R = F_Y + R $$
the flow rate $F_Y$ of stream $Y$ is equal to the feed rate $F$, i.e. $F_Y = F = 1500$. From an $N_2$ component balance we deduce:
$$ Fx + Ry = (F + R)y = Fy + Ry$$
So:
$$ Fx = Fy $$
And so we conclude $x = y$ and so the composition in $Y$ is the same as in the feed $F$. We could have concluded this directly since it is given that no reaction occurs in process 1.
