I would like to perform parameters estimation for a differential equation from experiment. If the value of these parameters are obtained from several experiments (repetitions) where for each experiment different final cost function is obtained, how can I calculated the final parameters values from these experiments? Thank you.
  • $\begingroup$ Have you considered the tolerance on each input value? What is the effect of all these on the output? $\endgroup$
    Dec 8 '17 at 6:33
