I understand this is a multifaceted question and I apologize . All of it is relevant to be understood.
On Earth Fly wheel storage devices are used as an alternative to batteries. Even with magnetic bearings these devises expand and contract making the clearance between parts an issue. Between the Earth and Moon temperature can rang from −270 °C and −454 °F.
Maintaining the bearings in them and the weight make them less efficient then batteries. Transporting them while they are spinning is also an issue. Moving parts that touch wear out. Bearing must be maintained and has it own set of issues.
I propose this as an alternative: This type of magnetic levitation below can be used in place of the magnetic bearings at 0 gravity and possibly on Earth or moon. Are flywheels used in space and in this way?
The lower drawn model below on the left will work on Earth but the gravity and air slow it down. No air on moon even better in space. The flywheel can be much heavier and be contained/entrapped using 2 magnetic bases and the magnetic core in the center of the flywheel.
Using timers to apply Gauss to a curved edge of the magnetic core it could be spun faster similar to spinning a basket ball on your finger with out knocking it off the axis, but also like a brushless motor. This would also be easier to transport.
Would there still be any friction other than when electricity is collected or Gauss is applied while spinning? The picture below is my version of a bearingless version of a flywheel storage devise . The design is basic, but is it plausible? When up scaled? Why not?
I am hoping someone could improve the design. The disks would be 2 parts to a space station. The flywheel would be large and heavy to the point of simulating gravity if you where standing inside the drum also heavy enough where power drawn shouldn't cause a noticeable shift in gravity. It doesn't have to spin fast if it is heavy. Since the main part do not touch they will last indefinitely. Constructing the magnets can be done in parts.
This link demonstrates well.
