When the absolute pressure dips below the vapour pressure, cavitation occurs. Why would dynamic pressure be taken into account in this case?
Because dynamic pressure is contributing to the total pressure and, when checking for the possibility of cavitation all terms must be included or at least accounted for.
  • $\begingroup$ So the total pressure, not the static pressure determines whether cavitation occurs? $\endgroup$ – Michael Nov 12 '17 at 12:18
  • $\begingroup$ One must account for the static head pressure along with any momentum associated pressure $\endgroup$ – takala Nov 17 '17 at 4:41
According to Pump & Systems,
Note that suction pressure is stagnation pressure (total pressure); it includes velocity head. Adding velocity head puts all pumps on the same basis, otherwise a pump would require different amounts of NPSH when tested with different sizes of suction lines (assuming that suction pressure is measured in the suction line, which is normally the case).
