I want to lift something in the air with a stepper motor. If the object is 1kg and I want to keep it in the air for 12 hours. Is it a good idea to keep the power on the motor all that time? Will it draw excessive amount of power? Ideally I would like to cut power to the motor when the movement is done, but then, will the motor be able to hold its position?
  • $\begingroup$ Hold it with a clamping device ie some type of brake, not the motor. $\endgroup$
    Nov 8, 2017 at 15:16
  • $\begingroup$ if you do this make sure the motor is rated for such continuous duty. $\endgroup$
    – agentp
    Nov 9, 2017 at 15:25
  • $\begingroup$ What is relevant is not the weight but the torque $\endgroup$
    – user253751
    Mar 31, 2023 at 15:12
Depends on how much weight and the motor.
Some stepper motors have detent torque. This is the torque they will hold without consuming any power.
They also have a holding torque for which you need to supply power.
The most fool-proof solution is to use a external brake.
