I am working on a project which involves applying electrical load across a metal contact filled with lubricants (bearing applications). However, I am missing one of the blocks as attached and I cannot figure it out what material this is. Looking at the posts here, I am presuming this must be some copper alloy such as brass, however, I know that the rotating disc that this block sits on is of brass material and that can raise issues such as wear due to the presence of similar materials?
Any suggestions what material I can use for this application to not damage the discs while providing good conductivity?
