What is most effective way to apply linear actuator to move a lift within a small sized space?
I.e. for example, for 14", which is total 820mm, to move a 330 mm lift in 740mm height box (width and depth are not limited)?
Sign up to join this communityWhat is most effective way to apply linear actuator to move a lift within a small sized space?
Multiply the distance moved using a lever, but the input force needed increases...
