I was reading some articles about acoustic levitation and I was wondering whether it is possible to lift a 100 kips load off the ground for about 0.5-1 inches with that. If it is, how should I calculate how much energy I need to deliver to a ultrasound speaker and effectively concentrate with a lens that can be used to produce such lift on an object.
I am not very familiar with this subject, so forgive me if I am asking some pretty dum question here. Thanks!!
Edit - Somebody apparently downvoted the question without saying why, I don't exactly know why. But I thought I should put some additional info to help people understand what I am referring to. Showing some "effort".... It is such a new field that there are not a lot of articles on how you calculate something like this and what is realistic.
  1. Acoustic levitation made simple
  2. Researchers demonstrate acoustic levitation of a large sphere
closed as too broad by user16 Dec 18 '17 at 1:45
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • $\begingroup$ I don't know why people would down vote without a proper explanation... Where did that come from??? $\endgroup$ – Isa Nov 3 '17 at 13:57
  • $\begingroup$ +1, doesn't seem to be an unreasonable question to me. It is an obscure area of research after all. $\endgroup$ – Wossname Nov 3 '17 at 14:36
  • $\begingroup$ you should realize this is an international forum and most folks wont know what a "kip" is. ( He wants to acoustically lift 45 metric tons ) $\endgroup$ – agentp Nov 3 '17 at 20:09
  • $\begingroup$ ... the fact that levitating a styrofoam ball warranted a paper in Applied Physics Letters should give a clue about whats feasable... $\endgroup$ – agentp Nov 3 '17 at 20:42
    $\begingroup$ Erm, but that device in there is really small. Can we just make a super size replica and lift like a much heavier object as long as it is a small distance, like 1 inch? (And I don't think kips is unreasonable... It is a unit of measure, albeit not a familiar form that you use all the time. For your reference, I was raised in Asia and I have no issues with the use of either. 100kips = 444kN for reference...) $\endgroup$ – Isa Nov 3 '17 at 21:13
