-1
I am going to have a spherical pressure vessel made. I need to know which grade of stainless steel suits best. The pressure vessel will contain liquefied diluoromethane at 1.8Mpa with tetrabutylammonium hexafluoroborate. The pressure vessel will also be cooled to temperatures as low as -60 degrees Celsius and must have very poor electrical conductivity qualities to be able to make sure the stainless steel doesn't interfere with the experiment. With this knowledge can you recommend the best stainless steel for the job. Thanks.
P.S. The pressure vessel will be very small so please take this into account.
  • $\begingroup$ Stainless steel conducts electricity - why do you think it will be a "poor" conductor? Have you considered coating the surface? $\endgroup$ – Solar Mike Nov 1 '17 at 12:45
  • $\begingroup$ well is there any other metal which displays all the properties I mentioned and is electrically unconductive $\endgroup$ – Matt01 Nov 1 '17 at 13:55
  • $\begingroup$ You need to check out the properties of metals... see thoughtco.com/metals-versus-nonmetals-608809 $\endgroup$ – Solar Mike Nov 1 '17 at 14:59
  • $\begingroup$ some reason to restrict yourself to metals? What does "very small" mean? $\endgroup$ – agentp Nov 1 '17 at 18:22
  • $\begingroup$ Very small means the vessel itself will be able to held in your hand small $\endgroup$ – Matt01 Nov 1 '17 at 19:27
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
