I am working on a project. A water level indicator using ULN2003. Now I want to integrate a 7 segment display to indicate the water level. How?
    $\begingroup$ This question is probably better suited to the electronics SE (electronics.stackexchange.com) $\endgroup$
    – L Selter
    Oct 31 '17 at 8:34
I am assuming you have a micro controller driving the ULN2003. How about the following sketch.
connecting 7 segment display to ULN2003
This show how to connect the segments and provide power to the display.
Following chart has some guidelines on how to drive the 7 segment display.
7 segment display drive signals
These should get you started.
