-1
When a reservoir is used to store water for electricity, it's pipes are usually laid in several segments on the ground to reach its source, such as a lake. It seems that if the pipes went directly to the lake by being suspended, less piping could be used and less energy lost due to friction would occur. Why are systems not built like this?
closed as unclear what you're asking by Wasabi, Fred, Nick Alexeev, hazzey, Mark Oct 30 '17 at 14:55
Please clarify your specific problem or add additional details to highlight exactly what you need. As it's currently written, it’s hard to tell exactly what you're asking. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
    $\begingroup$ Some pictures would help illustrate what you mean $\endgroup$ – Fred Oct 28 '17 at 0:24
Suspended pipes are heavy and need support - any change of direction also creates a force - and there is the aerial impediment to consider : Birds, parachutes planes etc.
Also some "pipes" are cut directly into the rock saving on material costs and consider that some of these pipes have a water flow rate of 45m3/s so the inertial forces are massive.
