Viscosity is resistance to the motion of fluid layers sliding over one another. Density is a measure of forces of attraction between atoms or molecules of same species. Is there any relation between the two?
No, mercury is very dense but pours easily Honey is lighter but is very viscous - (changes with temperature though)
Density and viscosity are two different characteristics of a fluid.
Viscosity has the units Poise for dynamic viscosity and Stokes for kinematic viscosity.
  • $\begingroup$ Stokes & Poise are old metric names from the gram-centimetre-second system, that was used by laboratories. In the SI system, there are no special names for the units for [viscosity] (en.wikipedia.org/wiki/Viscosity) & density. The SI units for viscosity are Pa.s, or (N.s)/m2 or kg/(s.m), while the SI unit for density is kg/m3 $\endgroup$
    – Fred
    Commented Oct 8, 2017 at 23:53
  • $\begingroup$ Says here that it is centipoise (cP) and centistokes (cSt) ...rheosense.com/basics/viscosity-units obviously depends on the source as it varies by country... $\endgroup$
    Commented Oct 9, 2017 at 5:10
