10
I hear that designing the thermal efficiency of such systems is very difficult. I'm not sure why, though, and I am interested.
On the one hand, I bet the heat is somehow a function of the total power in the system. On the other hand, as individual bits are flipped, I imagine the heat migrates around the die.
How does heat move around the die, and how does this affect the cooling of the CPU? Are specific compensations made to accommodate the movement of heat?
  • 3
    $\begingroup$ First, welcome to Engineering.SE! As you acknowledge, this is a very deep subject, and this is a broad question on that subject. I would suggest narrowing your question down to a more specific aspect of this field, otherwise you may not get a satisfactory answer. $\endgroup$ – Trevor Archibald Feb 19 '15 at 13:24
  • $\begingroup$ Can you suggest a narrowing? I'm not well versed in the subject $\endgroup$ – baordog Feb 19 '15 at 13:25
    $\begingroup$ Well, in thermo we're typically concerned with how much heat the system (CPU) is generating, how much power it'll take to remove that heat from the system, what kind of efficiency is typical for CPU cooling, and what might be done to improve that efficiency. All of those together are probably a bit much, but one or two would be answerable. You might also ask how the heat moves around the CPU as it's used differently, and what challenges that provides to cooling. $\endgroup$ – Trevor Archibald Feb 19 '15 at 13:35
    $\begingroup$ @TrevorArchibald: I believe a great startup would be an answer that skims the surface of all these factors instead of going in-depth into any single one; an overview of the generalized problem instead of detailed analysis of any of its sub-divisions, a starting point to ask more focused questions from a somewhat more informed standpoint. $\endgroup$ – SF. Feb 19 '15 at 16:45
All the fundamental issues about the Thermodynamics of the heat sink design are well presented here (make sure not to miss the pretty CFD pics at the bottom of the page).
What's not presented here is the larger flowfield structure inside the computer case. In more recent years, with the push to get CPU speeds at 3+ GHz, there has been more work in designing (1) ducted fans as well as (2) flow ducts into the casing which pass air quickly in and out of the case.
Ducted fans produce more thrust (or move more air) than regular fans, because the duct causes less flow leakage around the tip which happens to be radially-speaking the highest velocity point of the fan. (This is a similar concept to wing tips on planes). So, the blade tip is the place on the fan that can move air the fastest.
Regarding flow ducts within the casing, the idea is to use the Bernoulli effect of a nozzle to accelerate the flow over the heat sink so that it can remove heat as fast as possible. This has especially become popular for overclockers trying to reach speeds of 4+ GHz (e.g. see http://www.overclockers.com/ducts-the-cheap-cooling-solution/).
The desire to produce faster and faster CPU's really have pushed the need to design better cooling systems. Topics such as liquid or nitrogen cooling are not discussed, but are also alternative methods to try to more efficiently cool the CPU, especially for overclocking at speeds above 5 GHz (e.g. see http://www.tomshardware.com/reviews/5-ghz-core-i7-980x-overclocking,2665.html).
Finally, I leave you with something to think about... I once heard the heat produced by a CPU running at 10 GHz is equivalent to the heat of the sun. There is a pretty good discussion on that topic here: http://www.reddit.com/r/askscience/comments/ngv50/why_have_cpus_been_limited_in_frequency_to_around.
  • $\begingroup$ (but the heat of the sun is equivalent to the heat of a compost pile, so don't read too much into it) $\endgroup$ – user253751 Nov 5 '20 at 16:57
The thermal system around a modern processor chip is indeed complicated and a major design focus. For both electrical and economic reasons, it's good to make individual transistors in a processor small and close together. However, the heat comes from these transistors. Some is dissipated all the time just because they sit there with power applied. Another component occurs only when they switch states. These two can be traded off to some extent when the processor is designed.
Each transistor doesn't dissipate much power, but millions and millions (literally) crammed together in a small area do. Modern processors would cook themselves in seconds to 10s of seconds if this heat wasn't actively and aggressively removed. 50-100 W is not out of line for a modern processor. Now consider that most soldering irons run from less than that, and heat a chunk of metal with about the same surface area.
The solution used to be to clamp a big heat sink onto the small die. In fact, the heat sink was a integral part of the overall design of the processor. The package has to be able to conduct the heat power from the die to the outside, where the clamped-on heat sink can conduct it further and eventually dissipate it to flowing air.
This is no longer good enough as the power density of these processors has gone higher. High end processors now either contain some active cooling or a phase change system that moves heat from the die to radiating fins more efficiently than plain old conduction through aluminum or copper did with the old heat sinks.
In some cases Peltier coolers are employed. These actively pump heat from the die to someplace else where it is easier to couple to the air flow. This comes with its own set of problems. Peltiers are rather inefficient coolers, so the total power that needs to be gotten rid of is significantly larger than just what the die dissipates. However, the active pumping action can help, even if the radiating fins eventually are much hotter. This works because the aluminum or copper of the radiating fins can stand much higher temperatures than the semiconductor die can. Silicon stops acting like a semiconductor at around 150°C, and real circuits need some operating margin below that. However, heat sink fins can easily handle much higher temperatures. A active heat pump makes use of this difference.
In the past there have been processors cooled with flowing liquid nitrogen. This doesn't make economic sense for ordinary desktop PCs with today's technology, but heat management has been a important part of computer design pretty much since the beginnings of computers. Even back in the 1950s, keeping all those vacuum tubes from melting each other was something that had to be carefully considered.
  • $\begingroup$ The primary advantage of the peltier modules comes from temperature gradient: it's much easier and faster to cool an object (in ambient temperature of 24C) from 300C to 200C than from 100C to 40C as power dissipation is proportional to temperature difference between the object and the surroundings. That way, even though there's more heat to dissipate, it's easier to dissipate as the heatsink runs at considerably higher temperature than the CPU. $\endgroup$ – SF. Feb 25 '15 at 0:10
