I was wondering if there are any window mounted split air conditioners in US market or anywhere else - One in which compressor and radiator hang out of the window and only evaporator is inside the room. I was able to pull up many patents from as early as 1938 with same idea but don't think a commercial product exist. Any thoughts why it could be so?
Here are some patents and more mentioned in their reference section:
https://www.google.com/patents/US6568201
https://www.google.com/patents/US2268451
10
  • $\begingroup$ I'm a bit confused as to what you would use it for. Are you intending to run a split system with a window open? $\endgroup$
    – JMac
    Sep 26 '17 at 20:35
  • $\begingroup$ from the patent "object of this invention is to provide a conditioning unit having a portion passing through the window but arranged .. to permit the window to be fully closed or fully opened without .. moving the conditioning unit away from the window" Not a bad concept, but I would suppose the free market has not provided demand for such. Undoubtedly it would cost significantly more than a compact window unit $\endgroup$
    – agentp
    Sep 26 '17 at 23:57
  • $\begingroup$ Idea is to keep the window unblocked. Traditional window units blocks the window. Here is a similar patent from Whirlpool filed in 2001 google.com/patents/US6568201 Take a look at Fig 4 & 6 I wouldn't expect it be a lot more costly compared to a window a/c. An extra motor and some housing changes is all that it needs compared to window units. I would certainly buy one since I would love to keep my windows unblocked. $\endgroup$
    – Jean
    Sep 27 '17 at 14:08
    $\begingroup$ There are in fact plenty of "portable" (google portable ac) units that use hoses to move air in/out. You could obviously pass the hoses through a window. (In fact folks do just that with windows that wont support a traditional unit). If you are thinking of actually splitting the unit and passing refrigerant lines through a window I think you'd have issues making a movable system sufficiently robust to contain the freon (My guess a pile of EPA red tape as well ) $\endgroup$
    – agentp
    Sep 27 '17 at 15:42
    $\begingroup$ @Jean If you're going to permanently affix a unit, I don't see how it would be any easier to go through the window. The only difference between what you're proposing and a split system is that you want to run your piping through a window instead of through a wall. The thing is, now you have a window which is stuck ajar (or ajar and sealed). It seems like it would look a lot worse than running a regular split through the wall, mounted so that you don't even have to see the tubing. Technically you could buy a regular split unit and just run the pipes through the window if you really need to. $\endgroup$
    – JMac
    Sep 27 '17 at 18:28
Yes, there are "saddle" or "hybrid" units which are basically as you describe. See, for example, the SoleusAir WS3-06E-201.
photo of SoleusAir air conditioner
We rented one back in 1988 to cool our computer room so they definitely make them. The coolant tubes were about 30 feet long and as flexible as hose pipes. I don't know if they used gas or water as the coolant. But the outdoor side was hung out of an open window.
