I am solving problems from the book: Meriam Kraige Engineering Mechanics statics vol 1. The problem is as follows:
The sliding door rolls on the two small lower wheels $A$ and $B$. Under normal conditions, the upper wheels don't touch their horizontal guide. The question is to find out the force $P$ required to slide the door at a steady speed if wheel $A$ becomes "frozen" and doesn't turn in its bearing. The coefficient of kinetic friction between a frozen wheel and the supporting surface is $0.3$ and the center of mass of the 64 kg door is at its geometric center. We have to neglect the small diameter of the wheels.
My attempt
I calculated the normal reactions at the two wheels to be equal to $32g$ each. I then applied $P=0.3N$ which gave me the incorrect value of $P$ .I couldn't get where I am wrong.Any help shall be highly appreciated.Thanks.
