I would like to plug a 25A welder on a 10A house plug. I understand that it will not accept full power or the circuit breaker would switch. However, my question is if I may run under some lower power setting: for instance setting 70A out of 200A on the welder.
From a very simplistic point of view: A welding machine with a maximum of 200A for 25A@220V mean, the welder at 60A would require about 10A@220V
However, a welding machine is not such a simplistic situation and uses several variants of waves, AC or DC, several frequencies, etc. which make all more complex.
Question May I plug this 25A Welder on a 10A-protected house plug?
