Suppose, the wheels of a car were to be replaced with solid concrete wheels, which do not deform,flex, etc. Would the car not be able to accelerate, take corners, etc ?
I do not understand why is it necessary for tires to develop slip for them to be able to move the car.
  • $\begingroup$ It would work fine, just a lot less smooth of a ride. $\endgroup$ Sep 19, 2017 at 8:27
  • $\begingroup$ If so, when what's all the fuss about slip angles,slip Ratio, etc in the automotive world? There must be some problem with non-stretchable wheels. $\endgroup$
    – RedHelmet
    Sep 19, 2017 at 11:21
  • $\begingroup$ Something should flex out the disturbances from the ground, the sooner the better. $\endgroup$ Sep 19, 2017 at 12:38
  • $\begingroup$ I am guessing that what you really want to ask is "what if the wheels had infinite friction coefficient" in which case yes, you can never turn a corner because the wheels can never slip-twist with respect to the ground. You need either to deform the tire or allow breaking traction. $\endgroup$ Sep 19, 2017 at 13:24
  • $\begingroup$ Consider the solid steel wheels of a locomotive. Can trains accelerate? $\endgroup$
    – user6335
    Sep 22, 2017 at 12:55
