Im currently writing a model for a guidance law named Maintaining Guidance law.
The law looks as following: $$ a_{M} = [K_1,K_2]*[\dot{\lambda_T} ,\dot{\lambda_D}]'$$
Since im using a linear model I use the following calculations:
$$ \ddot{y} = \ddot{y_T}-\ddot{y_M}=a_T-a_M$$ $$ \dot{y} = \dot{y_T}-\dot{y_M}$$ $$ y = y_T-y_M$$
Where: $$\dot{\lambda} = \frac{y+\dot{y}*t_{go}}{V_{c}*t_{go}^2}$$
And K1 and K2 are vectors calculated before.
The engagement looks as following:
I tried to transform it into X-Y axis however I got stuck in few things I couldnt figure out as:
1) In this model, $\dot{\lambda}$ depands of $t_{go}$ which becomes small close to the end and makes $\dot{\lambda}$ huge ---> $a_M$ is huge ---> $V_M$ is not constant as taken in linearized models.
2) The same problems occurs when I use $v_{c}$. In all the linear model $V_c=V_{M}+V_T$ where the velocities are constant. How to use it then in my model since its not constant/almost constant.
Is there any tips of how to transform it to X-Y graph but still keep it linear?
Thank you!
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
