IFC files have an IFCMATERIAL property which names a material and is referenced by other components in the model.
The IFC file doesn't point to a materials library, doesn't indicate a system variable that points to a library and uses very general names such as "concrete".
How are these relations managed across multiple interfaces and systems? For example, I have an IFC exported from Revit, where I to import this into xBIM on a system without Revit, how would xBIM know what materials to bind to the objects?
Thanks.
