I am confused about the difference between NPT, outer diameter of a pipe, and nominal pipe size.
Let's say I have a 1/8" NPT pipe. Does this mean the outer diameter of my pipe is 1/8"? Is the nominal pipe size equal to the outer diameter of the pipe?
  • $\begingroup$ Welcome to Engineering SE. Could you clarify what you are confused about. Nation Pipe Standard is a thread standard, pipes are measured by the inside diameter, and Nominal Pipe Size is a pipe standard. An 1/8" pipe can have different ODs because of different wall thicknesses. None of these are the same thing but they are related. $\endgroup$
    – Drew_J
    Sep 8, 2017 at 23:49
    $\begingroup$ Can't have different OD because the threads always match. You can connect 2" sch 20 to 2" sch 120, etc. $\endgroup$ Sep 9, 2017 at 17:06
Pipe comes in different wall thicknesses, designated schedule 40, Sch. 80, Sch. 10, etc. Higher numbers are thicker walls. The outer diameter is the same for all schedules, so the inner diameter varies. The nominal size is close to - but not exactly - the actual inner diameter for schedule 40 pipe.
Here is a chart summarizing the dimensions
  • $\begingroup$ I have seen this chart before, and I still think I do not understand it. For instance, in the first row of the chart it says, "Pipe Size (inches): 1/8; External Diameter .405, Internal Diameter .27;" 1/8 = 0.125. So, why is pipe that has an external, and internal diameter greater than 1/8" called 1/8" pipe? I suppose this is what ASTM A53 states? $\endgroup$ Sep 11, 2017 at 16:48
  • $\begingroup$ wikipedia also has the same note about the nominal size roughly corresponding to schedule 40 inner diameter. en.wikipedia.org/wiki/National_pipe_thread. It is however clearly not true for the smallest sizes. They are effectively (inexplicably) a whole size off with 1/8 Sch 40 -> 1/4 Id, 1/4->3/8 ID , etc. $\endgroup$
    – agentp
    Sep 11, 2017 at 17:15
  • $\begingroup$ @ThomasWilk - The chart defines the dimensions, but as you say the name is deceiving for smaller sizes. Probably would have been better to call rhem "Red", "Yellow", "Green", and "Blue". But whether iy makes sense or not, those are the names and dimensions. $\endgroup$
    – Mark
    Sep 11, 2017 at 22:37
The NPS designation is a name that indicates a size but it does not define that size. Like "two by four" is the name of a certain size of lumber, it not the actual size of the lumber. There is a particular size of pipe that is defined by the name AND schedule ; such as 2 inch, schedule 80.
