Does anyone know what this mechanism for linear movement is called? I have a different model of something like this, and the black chain appears rigid, so I assume it is the mechanism moving the laser head. I could be wrong though.
1$\begingroup$ It's not clear from the picture. However the black chain-like devise is used to manage wires. $\endgroup$ – Eric S Sep 6 '17 at 1:06
$\begingroup$ @EricShain I just searched for "linear actuator cable management chain" and found the chain part. Apparently it's called a "cable chain". You can post it as an answer and I can accept it. $\endgroup$ – Winseven4lyf Sep 6 '17 at 1:18
Add a comment
The head probably moves by rack and pinion or a hidden timing belt.
The cable management is done by a cable carrier. It works by having each joint only have a limited rotation so that it can support itself when held horizontally.
