I have a setup with 4 cylinders placed next to each other in following configuration. The cylinders are made of .2mm stainless steel. I would ideally want to rotate them along their axis using a single actuator/motor. What would be the best mechanism to do so?
I'd like to keep the cylinders as close to each other, due to space constraints. Any references would also help.
  • $\begingroup$ research the Ariel square four engine... $\endgroup$ – Solar Mike Aug 23 '17 at 5:28
  • $\begingroup$ all in the same direction? $\endgroup$ – ratchet freak Aug 23 '17 at 11:18
  • $\begingroup$ One central gear of radius large enough four gears on tops of the cylinders don't mesh with each other. $\endgroup$ – SF. Aug 23 '17 at 11:22
  • $\begingroup$ One chain (or belt, or timing belt) around all of them. Somewhere along the chain is the gear connected to a motor. $\endgroup$ – Nick Alexeev Aug 23 '17 at 14:49
    $\begingroup$ Lovely. the chain mechanism worked really well! $\endgroup$ – touchaddict Sep 6 '17 at 12:34
