I have a pretty basic question.
I need to install a timing pulley on a ball screw shaft (6mm): http://uk.rs-online.com/web/p/products/2816419/
The processed end (the pointy side) of the shaft is secured by a support mount, I need to place a timing pulley on the other side. I'm not sure how to go about this. E.g. this pulley: http://uk.rs-online.com/web/p/timing-belt-pulleys/0744508/
Would a mounting hub or a pulley with a holding screw work? Thanks.
