What is difference between the tailboard and the bood lid? Can you show me where each part is?
Thanks for help.
Sign up to join this communityA tailboard would be the name of the opening panel found at the rear on a pick-up type vehicle, while a boot lid is the name for the panel that closes the boot or trunk. An SUV has the rear panel called a door and if the rear window opens it is likely to be called a hatch - also hatch-back.
