In both the Fukushima and Chernobyl incidents, widespread contamination would have been prevented had both facilities been enclosed within a larger structure. While existing plant designs call for hardened structures for the reactor itself, they often don't contain secondary and support infrastructure (Fukushima) or are insufficient to contain more explosive incidents (Chernobyl).
I'm curious if existing plant designs could be augmented with the addition of a large, non-hardened, dome structure that covers the entire plant. The dome would be able to contain escaped gasses simply by being hermetically sealed - and a sufficient distance between the dome and any potential sources of explosions means there's enough normal air to buffer and absorb the explosive shockwave, if any.
Such a structure could be built very cheaply - a geodesic hemisphere, for example, constructed of plastic links with inward-opening transparent plastic panels for natural light and ventilation. A fail-safe system would automatically close all panels to prevent the escape of unwanted gasses after an explosion.
There is some precedent for this, insofar as how's Chernobyl's reactor complex is now enclosed within the New Safe Confinement structure - except it's an ugly, opaque, and very expensive structure, constructed in a dangerous environment. Presumably my dome proposal could be built cheaply - and the cost/benefit of construction vs clean-up costs (multiplied by actuarial risk) make it a straight-forward decision - and given human penchant for safety theatre it would help "sell" nuclear power to the masses, but that is beyond the scope of my question.
So my engineering questions are:
- How big would a dome or other enclosing structure have to be in order to enclose all of a plant's at-risk structures?
- And wold the volume of air inside the dome be sufficient to buffer an explosion to eliminate the need to excessively harden or reinforce (and so, add weight) to the dome structure?
- Assuming that all of the panels in the dome structure are capable of opening and used for ventilation, would that be sufficient to prevent a greenhouse effect?
- In your opinion, is this proposal feasible or realistic?
