How do those mechanisms such as the ones in cars work - when you open a tray or glove-box, and it opens slowly by "easing in".
I would like to build my own compartment with a sliding cover that would slowly open by with the push of a button.
Thanks
One method is they use a piston/ cylinder arrangement that has a small hole to allow the air in / out to slow down the rate of movement caused by the weight or a spring .
As for a name : damper or damping piston comes to mind.
  • $\begingroup$ Thanks! Is there a specific name for these pistons? $\endgroup$
    – pufAmuf
    Jul 28, 2017 at 17:46
