What is meant by a "system curve" that is used to determine the operating point of a pump. I know what a "pump curve" is, but I often hear about a "system curve" being generated so that the pump operating point can be determined by where the pump curve and system curve intersect.
Imagine if you were pumping through a single pipe. That's all the pump does, is take in water from a source and pumps it along a very long length of pipe. Since this is just plain piping, the friction loss isn't difficult to determine, but you need to know the velocity to calculate the Reynolds number. Without it, you can't use a Moody Chart to calculate a friction factor to find out the loss. But, with a good estimate of the flow rate, the estimated range of the flow rate could be guessed at, and a friction factor can be guessed. With a friction factor estimate, but a flow rate unknown, you finally settle on the pressure loss across this long length of pipe:
$$\Delta P =f_D \frac{\rho V^2}{2}\frac{L}{D} = f_D \frac{8\rho Q^2}{\pi^2}\frac{L}{D^5}$$
Where P is pressure, Q is the flow rate, $\rho$ is the density, L is pipe length, D is diameter, and $f_D$ is the friction factor. Let's take cast iron 100mm pipe, highly turbulent regime, running for 10km. Plugging all the numbers in this theoretical situation, we come to (hypothetically):
$$\Delta P = 0.304 Q^2 \frac{kPa}{(\frac{L}{s})^2} $$
Now we have a formula to give an idea for pump sizing! More importantly, we have a curve. Plugging in any arbitrary value of Q (in L/s) would give you the pressure loss across the pipe in kPa. This curve is the system curve, and it naturally looks like a parabola. This is, in general, true for all fluid systems without any type of controls response (acting under natural behavior). You can plot this curve on top of the pump curve, and find out where the system will reach equilibrium.
Note, it isn't hard with such a simple system to get a lot of liquid out. More complex system have a lot more intricate mechanics, but the general parabola rule still applies. Thus, most people work through the complex mechanics of their system to simplify it into a single point. In our case, operating at 25 L/s would mean a pump that has to pump 190 kPa. This is the single operating point. Typically, many engineers will slightly increase these values, so they will always find an operating point that's safe. In this case, going to 30 L/s would mean a 275 kPa. Thus, the only parabola that goes through the point 30 L/s, 275 kPa and the origin (there is only one parabola that does this) would be the system curve.
$\begingroup$ Do you mean to say that P is the pressure in the paragraph below equation 1? $\endgroup$– J. AriJul 28, 2017 at 13:17
Usually a pressure / flow characteristic curve for a given power.
They are usually provided by the manufacturer.
Unless you do an engineering degree where you get to measure the flow rate, pressure, power, calculate the efficiency etc and then have to plot all the dimensionless groups etc to show what is happening.
$\begingroup$ And odds are unless you've made the pump yourself, there would still be a manufacturers curve available. I'd also highly suggest using that instead of a self-generated curve if you have the choice :P $\endgroup$– JMacJul 27, 2017 at 16:08
$\begingroup$ @JMac oh the profs had the original curves - part of the grade was how close you came! And it's bringing to mind names like Stannitz and Stodola... $\endgroup$ Jul 27, 2017 at 16:09
$\begingroup$ I think my question was unclear because I know what a pump curve is, but I often hear my MechE colleagues talk about deriving a system curve (for the plant equipment) and then they find where it intersects with the pump curve to determine the operating point. As a ChemE, I did not really delve into such considerations, I usually just have to read a pump curve for troubleshooting. $\endgroup$– J. AriJul 27, 2017 at 16:34
$\begingroup$ @J.Ari So the equipment obviously has some pressure/flow requirements (since it's hooked up to the pump). It also likely operates one some curve of acceptable values and associated efficiencies. Obviously they can only operate where they two sets of values "intersect". They probably trace the high-efficiency lines and find where the two intersect to get a pressure/flow setpoint. $\endgroup$– JMacJul 27, 2017 at 16:52
System curve is simply a plot of the required head against change in system flow rate, as the required head (mainly major and minor losses) increases with the increase in flow rate.
On the other hand, for a pump curve, you can see that the available head by the pump decreases with the increase in flow rate. So, if you put the two curves on a single plot (and if the pump is properly selected), you will have an intersection point between the two curves, and that's your operating point.
$\begingroup$ So, as I said in my answer a pressure / flow characteristic curve... $\endgroup$ Jul 27, 2017 at 18:42
