Mathematically, an eigenvalue analysis assumes the modal displacements are infinitesimally small, so the change in stiffness in the cable caused by the vibration is a second order effect which can be ignored.
This very-small-amplitude vibration is a good place to start understanding the behaviour of the structure - for example, look at how the frequency depends on the angle of the beam to the horizontal.
Of course if you are interested in large amplitude vibrations, the change in stiffness during each cycle of oscillation can not be ignored, but the vibrations are not sinusoidal anyway. Really, you can only simulate this by a time-marching transient dynamics analysis, updating the stiffness at each time step. The stiffness will vary along the length of the cable because its self weight will cause the tension to change along its length, and also because it is not straight!
In simple situations (for example oscillations of a simple pendulum) you can investigate the large amplitude behaviour analytically, but that assumes you know the deformed shape of the structure (which is trivial for a simple pendulum, because the massless string is always straight so long as it remains in tension).
You might be able to formulate the large-amplitude motion of your structure the same way as for a pendulum, if you assume the beam is rigid and the cable is massless and stretches along its length. You then will have only one degree of freedom, measured by the change in angle of the beam (or the cable) from its equilibrium position.
Even for large amplitude oscillations of a pendulum, the period is an elliptic function of the amplitude which can only be evaluated numerically (e.g. by a power series approximation). For anything more complicated, attempting an analytic solution is unlikely to give much quantitative information - though a phase-plane plot may tell you some interesting things qualitatively.
