Can a Prince Rupert's drop be made of metal instead of glass?
    $\begingroup$ Will the metal you are proposing have the same properties as that of glass? How does surface tension affect hot metal droplets compared to molten glass droplets? $\endgroup$
    Jul 1, 2017 at 20:52
  • $\begingroup$ I looked this up then realised as glass boils it traps te air bubbles as they escape unlike metals which bubble so when it hits the water air leaves faster leaving weakened maybe cool in a more viscous fluid? $\endgroup$
    – Shaun
    Mar 8, 2021 at 19:46
Sort of.
This is rendered a bit of a moot point as most metals already have the the sort of hardness and impact resistance that heat treating imparts on glass anyway so you are essentially approaching the problem from the opposite direction.
However it is certainly true that heat treating can create residual stresses in susceptible metals in a similar fashion, stainless steel with its high coefficient of thermal expansion and low thermal conductivity is particularly susceptible.
Also steels with sufficient carbon content can be dfferentially hardened by quenching so if you quench a thick enough section of high carbon steel you will get a hard surface layer with a softer core. Also the hard section will increase in volume, creating residual stress throughout the whole sample.
There are also various processes for surface hardening of steels, such as case hardening which works by diffusing carbon into the surface of low carbon steels.
The closest real world application is in ball bearings which tend to have hard surfaces and soft cores to combine surface wear resistance with toughness. This isn't exactly the same as a Prince Rupert's drop as you have a change of micro-structure going on.
There is also the complication that molten high carbon steel tends to start to burn in air so making an actual droplet might require an inert atmosphere, equally molten steel is generally a lot less viscous than glass so forming the 'tail' wouldn't work in quite the same way. Having said that you could achieve a similar effect by quenching from solid.
Fully hardened (ie quenched but not tempered) high carbon steels aren't that far away from the brittleness of glass. Indeed it is not unknown for quenched parts to spontaneously crack between quenching and hardening.
  • $\begingroup$ I was going to cheat and say "yes, by quenching a metal fast enough to form a metallic glass" :-) $\endgroup$ Jul 2, 2017 at 11:09
  • $\begingroup$ How about the explosive chain failure starting from the tail for the less flexible metals? Could this more violent given that metals are already more resistant? Although as I understand metals tend to be more resilient than glass because they can flex more without breaking. Metal Glass having looked it up seems to have good properties for this too. $\endgroup$
    – alan2here
    Jul 2, 2017 at 11:14
  • $\begingroup$ Ball bearings (the ball part) seem amazingly safe against, for example crushing forces. $\endgroup$
    – alan2here
    Oct 15, 2020 at 23:02
Diving deep, given the correct material/component, I was think if it is possible to use a strong external fast changing EM field (electro-magnetic) to control the shape of melting metal and keep it suspended/floating in space, and cool down using water or a high speed jet of liquid air.
this will result in a material as hard as rupert's drop with no tail (no achilles heel). this can be used for military and space exploriation. I was wondering if a similar process has been used (secretly) in military industry already.
----- pioneering towards the Prince Rupert's drop with short or no tail, in glass, and in metail.
  • $\begingroup$ That's intriguing. Also water is very efficient at cooling things. And the other answer suggests that this is like a ball bearing? $\endgroup$
    – alan2here
    Oct 15, 2020 at 23:05
