I am building a cart from (What Type of Tires and Wheels Do I Need to Make a PVC Beach Cart?). I have a wheel whose central diameter is 3 inches and the PVC for the axle is 1 inch in diameter. I am planning on cutting a wooden circle and attaching it to the wheel and cutting a 1.25 inch hole through the center of the wood so the PVC pipe can pass through the wood. Is this a good idea or are there better alternatives?
Here is a picture of the wheel and tire Wheel and Tire
  • $\begingroup$ are you purchasing trailer wheels for this project? There are better solutions, eg wheeleez.com/polyurethane-wheel-axle-kits of course if you are utilizing some old wheels you have on hand that's a different story. In any case this is really not an engineering topic, more diy.stackexchange material. $\endgroup$
    – agentp
    Jun 27 '17 at 2:42
    $\begingroup$ 3/4 inch pvc (1 inch OD) is awful small for an axle btw. How much weight are you planning? $\endgroup$
    – agentp
    Jun 27 '17 at 2:45
  • $\begingroup$ I agree that PVC tubing isn't likely to work. Just get some steel tubing. $\endgroup$
    – Eric S
    Jul 26 '17 at 14:52
What may be significantly easier is to make an adapter plate that matches the hole pattern on the wheel hub and a pvc pipe flange. The other really easy thing to do at this point is using a frame from a new four wheeled wheelbarrow. The wheelbarrow is belt from those environment, has roughly 1 ton capacity engineered in and it saves you a ton of time which I would assume is worth way more than the wheelbarrow. I hope that this helps.
  • $\begingroup$ I like the flange idea. How should I attach the flange to the axle? Should I just grease both or use bearings inside the flange? $\endgroup$ Jun 26 '17 at 19:29
