I have a non-linear system shown:-
$$\dot{x}_1 = x_2$$
$$\dot{x}_2 = -(1-\vert x_1\vert)x_2 - x_1$$
How do I determine the region in the state plane where the equilibrium state at the origin is asymptotically stable?
  • $\begingroup$ What are $x_1$ and $x_2$ functions of? Time only? $\endgroup$ Jun 21, 2017 at 17:37
As you might already know your system is nonlinear, which means that it is not trivial at all. See below for the plot of the system. The linearization around $(0,0)$ gives you the information that the eigenvalues have both negative real parts, which guarantees asymptotic stability in the sense of Lyapunov for the origin. From the plot, one can conjuncture a half-stable limit cycle. Which would imply that trivial equilibrium solution is stable inside the half-stable limit cycle. I doubt that you will be able to get the exact equation for the limit cylce.
In order to estimate the region of asymptotic stability, you could try to come up with a Lyapunov function, which is also not trivial. Alternative methods would be to use the index theory / Bendixson–Dulac theorem / Poincaré–Bendixson theorem (for the existence of the limit cycle), Method of harmonic balance / Poincaré-Lindstedt method / Multiple Scales to find an approximate equation to the limit cycle. Multiple Scales also allows you to investigate the stability of the limt cycle. enter image description here
-1
I suggest you graph $x_1$ and $x_2$ for half unit intervals between -3 and 3 for both variables.
Then work out the derivative of $x_1$ and $x_2$, and mark these on the graph.
Then examine the area where the marks go towards the fixed point (ie the origin). Which area around the fixed point end up going towards the f.p.?
