I want to optimise the size and shape of a magnet for a desired pulling force. (Please forgive my limited knowledge of magnetism).
A cylindrical magnet fixed to an object will hold it in place by placing a steel plate underneath. There will be a plastic sheet separating them. The poles are the ends of the cylinder magnet, (I know that's not ideal for maximising force); the magnet will be encased by aluminium.
What I Would like:
  • I will measure the holding strength of such a cylindrical magnet (known dimensions) directly on the steel plate. Given that, I hope to:
  • calculate the expected holding force of a similar magnet, with the variables being the new cylindrical magnet's dimensions, and the separator's thickness.
  • Accuracy is not crucial. (10-20% perhaps). Ultimately I will use that to optimise factors such as cost.
Factors that can be ignored:
  • Grade of magnet. (Assume materials and magnetisation are identical).
  • Thickness of steel plate: assume thick enough to simplify calculations.
I hope this is feasible!
  • $\begingroup$ How will you measure the pulling gorce? Will it be applied perpendicular or eccentric or even a sliding force? $\endgroup$
    Jun 11 '17 at 11:18
  • $\begingroup$ @SolarMike purely vertical, i.e. perpendicular. I will increase the separating force until it parts. $\endgroup$
    – CL22
    Jun 11 '17 at 11:27
