I've been given this bode diagram :
enter image description here I've been asked to find the transfer function only by using the bode diagram. It's the first time I'm doing this so here's what I thought.
The starting value is zero so the multiplying constant of the the transfer function has to be 1 and it is positive since the phase diagram starts from 0 degrees( it would start from 180 had it been negative)
From the fact that the starting degrees are 0 we derive that we have no pole or zero that is at the origin.
Also, the final degrees are -270 and the dBs are decreasing so I must have 3 poles.Am I correct?
Also ,I know that I can look at the curve , the dBs per decade at any point to see how many poles or zeros are acting. I can't get a good estimation though.It seems like it's 10 dBs per decade until the frequency reaches 10 rad/sec while I know it has to be a factor of 20 dBs. 60 dBs per dec mean 3 poles/zeros,40 dBs per dec mean 2 etc.
How do I know where the poles are if I can't tell where the angle of the curve changes? Is it clear and I can't see it?
By the way, I've been given the answer to check if I do it right in the end and it's as follows: $$ G=\frac{500}{s^3+20s^2+200s+500} $$ Also p =
-8.2390 + 8.6072i, -8.2390 - 8.6072i, -3.5220 + 0.0000i
  • 3
    $\begingroup$ I doubt that it is possible to deduce the transfer function from the given bode plot without doing some curve fitting. $\endgroup$
    – MrYouMath
    Commented May 25, 2017 at 18:51
