I am currently doing a control systems course and I was lead to believe that if a pole lies on the imaginary axis in the s-plane (i.e s=0), then the system was marginally/critically stable.
However, I come across this transfer function and plotted it in Simulink.
Analysis shows that there are 3 poles at s=-1, s=-3 and s=0. So because there is a pole at s=0, the system should be marginally stable right? But the output of the transfer function shows this:
To me, that is showing the system is unstable because the output is getting bigger and bigger as time goes on. Is this correct? Or is my understanding still flawed?
If the system is unstable, then why aren't any of the poles in the right half of the s-plane?
Thanks
