From the book "Design of Liquid Propellant Rocket Engines". Under stress analysis related pages, the author used an equation for finding the thickness of the wall needed for sphere under stress.
$$\text{Thickness of sphere wall} = \dfrac{\text{Yield pressure}\times\text{diameter}}{4\times\text{yield strength at 300°F}}$$
I would like to know the equation for tubes.
8
    $\begingroup$ Hoop, axial or radial? there are many sources that you can easily find to tell you this. $\endgroup$
    May 18, 2017 at 8:25
  • $\begingroup$ @SolarMike axial, but I am not dumb enough for not realizing the resources. $\endgroup$
    – Raze
    May 18, 2017 at 19:56
  • $\begingroup$ So, what stopped you? $\endgroup$
    May 18, 2017 at 20:28
  • $\begingroup$ @SolarMike stress formula is easy enough to find, but the wall thickness is another problem, and there is no resource I can find. Or I am just dumb $\endgroup$
    – Raze
    May 18, 2017 at 20:32
  • $\begingroup$ @SolarMike Pardon my obliviousness, would you mind pointing out my mistake. I have changed the title, does that make any better? $\endgroup$
    – Raze
    May 20, 2017 at 6:00
3 Answers 3
Assuming a very long cylinder (to neglect effects at the top and bottom of the cylinder) with a small wall thickness $t$ (to assume that the stress is constant across the thickness of the wall) and with mean diameter $d_{\text{m}}=d_{\text{inner}}+t$ you can easily derive the so-called Barlow's formula.
$$\sigma_{\text{tangetial}}=\frac{d_m}{2t}(p_{\text{inner}}-p_{\text{outer}})$$ $$\sigma_{\text{axial}}=\frac{\sigma_{\text{tangetial}}}{2}$$
Had to post this as an answer: enter image description here
Which deals with thick-walled cylinders : Source : http://www.engineeringtoolbox.com/stress-thick-walled-tube-d_949.html Or here, from Lamé's equations : http://www.mydatabook.org/solid-mechanics/stress-for-thick-walled-cylinders-and-spheres-using-lames-equations/#cylinder_axial_stress
  • $\begingroup$ After awhile looking at your answer and still confused, I did some research and found this website. Wall Thickness Calculator This is what I am looking for, did I mess up the names for these? $\endgroup$
    – Raze
    May 19, 2017 at 6:51
  • $\begingroup$ Check the names you use against theirs.... $\endgroup$
    May 19, 2017 at 6:55
As mentioned by @MrYouMath, you can use Barlow's Formula (see 1, [2] with a calculator for US units). In short the equation is $$P = \frac{2 S_y t}{d}$$
where:
  • P: pressure
  • $S_Y$: allowed yield stress
  • $d$ : diameter
  • $t$ : thickness.
if you are solving for the thickness:
$$t = \frac{d}{2 S_y P} = \frac{r}{ S_y P} $$
keep in mind the following:
  • In (the unlikely) case you end up with $d<20 t$, then the assumptions do not hold and you shouldn't use the results. You should use either FE, or analysis that can't be covered in this paragraph.
  • Regarding the selection diameter, you are better off selecting the outer diameter. Especially if $d>20 t$, there won't be any noteworthy difference. (consider the selection of sheet metal thickness for the pipe).
  • It is highly recommended, to use a safety factor N(>1). The factor should be proportional to the hazard caused by the failure of the pipe. (e.g. if you carrying a toxic fluid, or if the pressure in the pipe is so high that essentially its a bomb). In that case the equation turns into:
$$t = \frac{d\cdot N}{2 S_y P} = \frac{r\cdot N}{ S_y P} $$
