We have large scale aircraft with long endurance and much higher speed than birds. But it seems that aircraft of comparable size to birds (i.e. drones) have much lower endurance, top speed and flight range. What technologies are currently limiting us from achieving this?
1 Answer
Somebody needs to design a chocolate-powered drone. Yes, seriously.
The total energy stored in a 40AH 12V battery is about the same as the calorific value of five 100g chocolate bars from your nearest supermarket.
Source: from https://www.tesco.com/groceries/product/details/?id=254381873, "Tesco Everyday Value Milk Chocolate" provides 3840 kJ/kg, and the fully charged battery holds 40x12x3600/1000 = 1728 kJ
Find a way to pack that much energy density into drone (and also consider that unlike LIPO batteries, chocolate bars don't spontaneously combust if they are mishandled!) and the comparison between drones and birds would come out rather differently.
Of course, soaring birds (and sailplanes) can stooge around all day and night, getting their energy from thermals and the wave airflows over mountain ridges - but they still need some external power to reposition themselves to take advantage of those "free" energy sources.
$\begingroup$ What about the propulsion, is rotor and wing propulsion of comparable efficiency in the case of drones? $\endgroup$– RealMay 17, 2017 at 2:47
$\begingroup$ How much energy does a bird store? fat etc?? Also, what's the bird's brain processing power? It knows how to use thermals etc and where to find them - what drones have that capacity? What is the processing capacity of the drone? $\endgroup$ May 17, 2017 at 5:31
$\begingroup$ @Real The propulsion of birds is actually quite ineficient, unless they are gliding. They just win out on more compact and lighter design due to better power systems and materials. Batteries are heavy. $\endgroup$– joojaaMay 17, 2017 at 5:33
$\begingroup$ Of course you need a powered glider plane to get comparable efficiency. A quadcopter drone that keeps pumping air downwards while hovering in place won't get anywhere close to that. $\endgroup$– SF.May 17, 2017 at 13:37
