I have known that the view factor reciprosity is that
Ai x Fij = Aj x Fji
But i can't intuitively explain the logic behind this, i do know that the view factor Fij is the portion of the radiation emitted by surface i that is recieved by surface j
I have looked up for the proof but that doesn't seem to help much
Thank you
  • $\begingroup$ I haven't found a good, physically intuitive explanation either. What i do know is that if you consider the double area integral definition of the view factor, $F_{ij}A_{i}$ produces the exact same integral as $F_{ji}A_{j}$ because the order of integration is reversible. $\endgroup$
    – Paul
    May 12, 2017 at 16:02
-1
It follows from the zeroth law of thermodynamics.
If the two surfaces are at the same temperature, there is no net heat transfer between them, otherwise the temperature of one would rise and the other would fall.
See http://web.mit.edu/16.unified/www/FALL/thermodynamics/notes/node137.html
  • $\begingroup$ After reading the posted link, your response makes some sense. But as a stand-alone answer, it is very ambiguous how this fact leads to reciprocity. Your answer should make this connection more explicit. $\endgroup$
    – Paul
    May 15, 2017 at 17:14
