Which case is used to check the drift and P-delta for a building according to ASCE ?
  • Static lateral force procedure (with a period Comparing T the real fundamental period with CuTa)
  • Static lateral force procedure (without comparing T with CuTa)
  • Modal response spectrum analysis (without scaling)
  • Modal response spectrum analysis (with scaling)
  • $\begingroup$ Do you have an endless supply of questions? $\endgroup$
    May 10 '17 at 5:49
  • $\begingroup$ I am a student doing a project that is why all the questions sorry $\endgroup$
    – J.Daou
    May 10 '17 at 5:53
  • $\begingroup$ If you explained that as part of your questions, then it may help the responses you receive. $\endgroup$
    May 10 '17 at 6:00
