I am trying to build a robot which would plant seeds instead of humans doing it (lettuce, radish and so on). The only problem i have so far is picking an individual seed. How could i do it? I've seen some discs designed especially for such appliances, but those are really expensive and i think that there has to be an alternative.
The farmbot uses a small diameter tube and a vacuum pump to pick up a single seed.
