In the book (photo 1 ) , it's stated at the left span, the fixed end moment is clockwise , while on the right span , the fixed end moment is anticlockwise . But , accroding to wiki (photo2) , it's stated that at the left span of the beam , the fixed end moment is anticlockwise , while on the right span , it's clockwise ...
In both cases , clockwise moment is assigned as positive . Which case is correct ? I'm confused . ht//en.wikipedia.org/wiki/Fixed_end_moment hhf sfsf
Everything if fine. You can use any one convention. Don't change conventions while doing a project. Keep it same all the time.
Also I would add: Your book shows moment formed inside the beam. Wiki shows moment formed on the end walls. Both are correct
  • $\begingroup$ excellent advice and a concise correct answer. $\endgroup$
    Apr 21, 2017 at 10:32
