I have a vessel that has a pressure measuring device. The value it shows as the pressure inside the vessel is 6 inches of water column. Is inches of water column meant to always be used as gauge pressure, or does one have to specify gauge vs atmospheric?
Inches of water is conventionally used as gauge pressure, not absolute. You could conceivably specify it as inches of water absolute, but that would be an unusual use - sub-atmospheric pressures are more commonly measured in inches or mm of mercury.
