I want to have water source on the 2'nd floor of our house so I can wash stuff there without going down to our 1'st floor... Is there a way to make water rise from 1'st to 2'nd floor?
  • 4
    $\begingroup$ Yes its called a pump $\endgroup$ – joojaa Apr 1 '17 at 19:41
  • $\begingroup$ I trust everyone noted the date of the post. (Everyone except "community" that is ! ) $\endgroup$ – agentp May 2 '17 at 13:52
Add a water pump on the main floor of your house that pumps it to the second floor. Or, assuming your house is connected to a city plumbing and water system have an extension line added to the second floor, using the city main pressure.
  • $\begingroup$ If a pump is needed, then a water storage tank on the 2d floor will be needed to provide smooth water flow, at uniform pressure, on the 2nd floor. $\endgroup$ – Fred Apr 2 '17 at 1:57
  • $\begingroup$ I didn't think that smooth water flow was a requirement given that the question was for 'washing stuff'. Most pumps can supply fairly regular pressure and flow, regardless a flow regulator would take care of that. $\endgroup$ – Diesel Apr 2 '17 at 2:19
  • $\begingroup$ You can get water to pump itself ... but you need an available head : see hydraulic ram $\endgroup$ – Solar Mike May 2 '17 at 5:51
  • $\begingroup$ If you are using a hydraulic ram, then you have a pressure source. i.e. city main pressure. $\endgroup$ – Diesel May 2 '17 at 13:26
