I accidentally inserted a mesh edit item and tried moving a node, but now can't remove it. The context menu doesn't have any helpful options and I don't see any relating tools in toolbars. How to remove it?
  • $\begingroup$ There seems to be an answer already, but both your question and that answer would be improved by including screenshots $\endgroup$ Feb 21, 2018 at 11:47
I figured it out. First right click your mesh in the project tree and then click "Clear Generated Data". Then, right click, say your "Node Move", there should be a "Delete", click "Delete", then right click your "Mesh Edit" and there should also be a "Delete", click that.
right click on mesh edit and generate. once it turns into green tick then right click again and there will be an option to delete
