Is it possible to detect specific UVB wavelength ranges using just a UVM-30A UV sensor or similar.
The sensor in consideration is GUVA-S12SD.
Seems to indicate that it generates a specific current level when sensing a specific wavelength, but because its sensing a range of wavelengths I guess you get the summation?
Is it possible to use any techniques to perform a UV spectral analysis on the output so as to detect the presence of a specific wavelength band.
It also important to determine relative intensity over time for the band. Is this anyway possible?
I'm not an engineer, but I can do any programming necessary.
Can anyone help!
Your spec sheet lists the following:
Spectral Detection Range λ 10% of R 240 - 370 nm
That means: over the range 240 to 370 nm, the responsivity is at least 10% of the peak responsivity (R). So look at the spec for R:
Responsivity R λ = 300 nm, UR = 0 V - 0.14 - A/W
The responsivity at other wavelengths is shown to be quite small in the following graph. A brief ride on the InfoSuperHighway suggests GaN detectors in general have that sort of shortwave (and longwave) limit.
As to your other questions: rather obviously you cannot determine what the input wavelength is from the electrical output, as there is only one output. You would need a set of narrowbandpass UV filters to measure a restricted band with this device.
