I have mounted a piezo-ceramic ultrasonic transducer (MODEL # SMD10T2R111WL, Vendor Website: PIEZO CERAMIC DISC 10X2MM R 215 KHZ WIRE LEADS) under a plastic tank using epoxy. Please see the below picture.
I am trying to confirm that the wire did not get detached from the transducer while mounting. Is there a way to test it. The two wires that are soldered to the transducer are not connected so there is no way to check the continuity of the wires using multi meter short circuit test.
