I have a system in which there is a screw with an electrical contact on it. When the screw is in all the way, one electrical connection is made. When it is out all the way, another connection is made. If it is in-between, no connection exists and my circuit doesn't work. I can adjust the endpoints which determine what is "in" and what is "out". The piece is from a garage opener that I am trying to repurpose. Here is a picture of the system.
I can control my unit with this setup, however I would like to use a light switch, since turning a dial really isn't as easy as flipping a switch. The lightswitch, unfortunately toggles between on and off. I would like to control between connections 1 and 2 instead, since another switch gives power to the unit. Is there a way I can do this or am I just going about this entirely the wrong way?
