I have a CNC that does not understand the G81 code for drilling. G-Simple looks to be configurable but I am finding it difficult to find information on it. It looks to have a "USE" command with a "G81" parameter but no idea how to make it not use this command and just drill a hole by constructing the movements itself. Just a simple CNC so not too bothered about the timing etc.
$\begingroup$ Does your post processor have settings? Can you disable "canned cycles"? Sometimes you can edit the drilling output and you can customize the output to get what you want. I don't know G-Simple. $\endgroup$ – GisMofx Mar 10 '17 at 23:59
$\begingroup$ G-simple is producing the g-code that I am then sending to the cnc. There is no intermediate file format. I think that is what you are implying. $\endgroup$ – BillyBag2 Mar 12 '17 at 10:00
Add a comment
